SailNet Community - View Single Post - Holding tank size
post #5 of Old 02-14-2013
PorFin
Seņor Member
PorFin's Avatar
Re: Holding tank size
Joellen,
Suitable tank size depends a bit on your cruising plans and your crew's preferences/habits.
I'd recommend you start your analysis from another direction: How often will you have access to pump-out and/or off-shore dump options?
FWIW: We've got a tank that's about the same size as your current one. We lived aboard for a couple of years. We did the Loop, though we did have a few extended stays in several locations (Brunswick, GA; Marathon; Oriental, NC; Holland, MI) -- and the only time the holding tank size became an issue was when we were on the Black Warrior stretch of the Loop above Mobile, AL.
________
'85 BYB Vagabond 39
PorFin is offline
