SailNet Community - View Single Post - Newbe with no experience buys big boat
post #210 of Old 02-15-2013 Thread Starter
davidpm
davidpm's Avatar
Re: Newbe with no experience buys big boat
Originally Posted by glenndamato View Post
davidpm:
The VOLUME of water getting below was what got me. It was not from the "big"holes: the two deck hatches and the ten new bronze ports. I forward deck hatch did not leak after it was properly adjusted. There were no clear, obvious entry points - the water was just "there," mainly appearing in lockers and the bilge, and the hull-deck joint is the only place I could think of, mainly because you can't directly see it at all in the DE38.
Leaks can be maddening, I've been there.
As far a volume goes it is amazing how much water can come in a small hole especially if it is under pressure.
I was in the gulf stream with a race boat with a retractable sprit. The minimal space between the sprit and hole it slid in was enough to make 7 of us have to bail with buckets.
The fact that the water was in lockers and you couldn't see anything leaking on the deck sure does sound like HD joint.
Bummer because there is no clear way to be sure that is not a problem on another boat.
davidpm is offline
