SailNet Community - View Single Post - Frozen rudder shaft Hinterhoeller 28
post #162 of Old 02-16-2013 Thread Starter
rbyham
rbyham's Avatar
Re: Frozen rudder shaft Hinterhoeller 28
Yes I would use a multi saw for a clean perpendicular cut just below where all that old stuffing box remnant it. I that would leave me with a clean new SS rudder tube but about 3/4" shorter. It is a very solid unit and everything would fit right back into the hull. With fresh bedding and glassing from inside it should be even stronger than glassing in a fiberglass tube . I would have to glass first and then drill new holes up through so bolts go in last.
rbyham is offline
