SailNet Community - View Single Post - Frozen rudder shaft Hinterhoeller 28
post #164 of Old 02-16-2013 Thread Starter
rbyham
rbyham's Avatar
Re: Frozen rudder shaft Hinterhoeller 28
I tend to agree with you Paul. I think cleaning all surfaces and re bedding would do the trick. Glassing would probably be overkill. I am thinking a stuffing box like Denise shows above to fit to top of tube. Would be a fairly easy refit. Someone asked about a backing plate on outside of hull to create sandwich of hull but there was nothing of that sort originally. Just the four bolts up through the hull with washers and nuts inside.
rbyham is offline
