SailNet Community - View Single Post - $6,600 to rebuild Atomic 4? replace/rebuild
post #26 of Old 02-16-2013
tommays
tommays's Avatar
Re: $6,600 to rebuild Atomic 4? replace/rebuild
Moyer gets between 3000 and 6000 + dollars for a rebuild
Now I know your spoiled because you live in a freshwater area BUT I own TWO saltwater A4s and even with the unit in Seafever having been converted to FWC 30 years ago
I can assure you unless you can drill out bolts much faster than me you will not have one apart in 10 days let alone 10 hours because I had to use supreme caution to break as few things as possible to return it to its current state and that was still over about 2000 in parts as I forgot about all the stuff I used from my second motor and did not have to buy
Stuff like rust wiping out the seal area on the output coupling Is a 65 dollar part and it just keeps going up till you hit a pretty big number
If seafevers block had needed a bore job you would have had to drill out ALL 18 studs and a whole bunch of other stuff to get it to the point it could even be put in a boring machine
mucho rust
The donar motor saved me mucho money
The motor mounts that now move ,water pump that pumps and valves SO you can service the impeller without dumping the antifreeze was over 600 dollars alone
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
