SailNet Community - View Single Post - Installing a propane sniffer
post #4 of Old 02-18-2013
jackdale
jackdale's Avatar
Re: Installing a propane sniffer
The propane hose should be one piece from the solenoid to the stove with no connectors. The leak will likely be either at end of those fittings. If it is in the propane locker, the propane should drain overboard. If it is at the stove end, it will trigger the sniffer.
If the sniffer does go off, turn off the tank. Do not operate any electrical switches. Open the bilge, open all hatches, get a breeze going through the boat. The propane should waft out of the boat eventually.
jackdale is offline
