SailNet Community - View Single Post - BOLT head in the Bilge...
post #12 of Old 02-18-2013
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: BOLT head in the Bilge...
Originally Posted by PorFin View Post
Monkey,
If you can manage to get a scissors jack under the engine, you can fit it up to support it when you remove the bracket.
Otherwise just use wedges - you can exert an amazing amount of force with wedges so be careful to just make them snug, don't pound them in. If the engine does settle a little - enough to make lining up the new bolts a problem, just tap the wedges some more until it rises into position - you can be very precise with them.
SloopJonB is offline
