Re: Storing spare propane tank
Check the RV sites the propane tanks are way cheaper. Only store ANY propane tanks 1 lb or larger in an approriate locker or outside the cabin. The l;ocker should have a drain at the bootom to the outside, not the bildge.
We use our second propane tank with an adaptor to fuel the magma grill eleiminating the need for the 1 lb bombs
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. ___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog- To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
