SailNet Community - View Single Post - NMEA over Bluetooth
post #28 of Old 02-19-2013 Thread Starter
TakeFive
TakeFive's Avatar
Re: NMEA over Bluetooth
Originally Posted by Alex W View Post
...You are using 38400, which I noted does send all sentences out of one NMEA port. At 4800 it does not. This is covered in the GX2150 manual on pages 16 and 17.
I have NOT configured my GX2150 in the way you say. The GX2150 gives you the option of multiplexing both AIS and DSC onto one wire (the gray one) at 38400. But you do not have to do that. You can instead opt to send the signals out the same way as done the GX2100, with DSC/DSE on the grey wire at 4800 and AIS on the brown wire at 38400. That is how I have my radio set up, and it has been working perfectly fine with my computer chartplotter for the past two years. The reasons I chose to do that are complicated and I don't have time to explain right now. But bottom line, I could plop your GX2100 into my boat and it would work in exactly the same way. Contrary to what you say, I am not currently taking advantage of the GX2150's option to multiplex DSC and AIS onto one port.
As for this guy's HX851, he simply needs one full duplex COM port, probably at 4800 (since his manual does not list any options). The GPS sentences simply go out the charging cradle to the Bluetooth adapter, which gets mapped to an emulated COM port in his computer.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
