SailNet Community - View Single Post - BOLT head in the Bilge...
post #18 of Old 02-20-2013
captainbri
Re: BOLT head in the Bilge...
depending on how much of the bolt shoulder is sticking out, you can use a chisel and hammer to make it turn. you want to walk it around you do not want to use it as if you were using a screw driver to turn it. basically the chisel would be flat against the block so when you hit it with the hammer it turns the screw.
captainbri is offline
