SailNet Community - View Single Post - Atomic 4 inboard vs outboard
post #13 of Old 02-20-2013
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Atomic 4 inboard vs outboard
2nd the Moyer Marine forum on the Atomic 4.
I have owned an A4 for over 10 years now. When I first got it I knew next to nothing about it but with the advice and help at the Moyer forum I have: replaced raw water pump, replaced fuel pump, replaced shaft, cutless bearing and shaft log hose, replaced the head gaskets.
You will feel much better about your A4 if you know your way around it. The tools you need to learn your way around are determination, a good ratchet wrench set and a can of PB Blaster or Kroil. Get the A4 manual and learn how to remove and clean the carburetor.
Everybody has one:
CalebD is offline
