SailNet Community - View Single Post - Extension cords @ dock
post #8 of Old 02-22-2013
swampcreek
swampcreek's Avatar
Re: Extension cords @ dock
Back when we had our Macgregor I rigged up a 17" x 17" solar panel (Forgot the wattage) I purchased off ebay, wired it to a solar panel regulator and ran it to a set of bus bars (+ and -). The + bus bar then was connected to a Perko switch (OFF, 1, 2, BOTH). #1 battery was a series 27 deep cycle and #2 battery was a larger lawn equipment battery for back up. Our electical system was mainly for lights and the stereo, and a few 12VDC cigarette lighter type plugs for 12 volt accessories. The engine was a pull start 8HP Nissan that I installed an under the flywheel alternator on and ran to the bus bars. (I was VERY PROUD of this system which from stock was only a single toggle switch and a lawnmower battery). Although we carried an extension chord I only used it to run the vacuum cleaner and maybe once or twice to top off one of the batteries that was at the end of it's life cycle. This system worked fine for us but we didn't have refridgeration or any other large current needs. If your needs are minimal I'd try to convince the wife to try relying on DC as an experiment and if succussful ditch the AC altogether. I even had a reversable 12VDC computor muffin fan ($15 online computor store) mounted to a clam shell vent in the engine well that could run continuously to circulate the cabin air. A sweet system indeed!
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
Many, many power boats
Life should be an adventure, not a guided tour!
Not all of us in the herd are sheep.
swampcreek is offline
