SailNet Community - View Single Post - Alternator wiring issue...
post #2 of Old 02-23-2013
Capt. Gary Randall
Capt. Gary Randall's Avatar
Re: Alternator wiring issue...
hello there, I am assuming that D+ field is directly connected to battery positive? in wiring scheme there will always be a current draw from your batteries. D+ field should be connected to the ignition switch on your engine and in the off position when your engine is shut down. It also should be on the other side of the shunt where it can monitor the voltage directly accurate/ ignition switch. The fact that you have an internally regulated alternator should be good in itself, as long as the field can monitor the voltage on the other side of the shunt. ( ignition switch) I would remove all the other homemade regulator and once the field can monitor the correct voltage you will find a improvement in the way your charge gauge reads. Directly because it cannot read correctly on the alternator side of the shunt assuming that you are using a amp gauge that is controlled by the shunt. Hopefully I have helped you out here. CaptG
[SIGPIC] The only difference between an ordeal and a adventure is your attitude!
Capt. Gary Randall is offline
