SailNet Community - View Single Post - Soft Sole Replacement
post #1 of Old 02-24-2013 Thread Starter
Squidd
Superior Sailor
Squidd's Avatar
Started my spring project list a little early, wanted to open it up and see what I was getting into...
I cut the top layer of glass off with a cordless saw and peeled back the sole...
Going to need warmer waether to thaw out the wet balsa core and get it clean and dry enought to replace, but I have a pretty good idea what I'm up against....Looks like 3/8" balsa core between two 1/8" glass layers...
I have enough 1/2" marine plywood to fill thew area, and was hoping to use that (assuming I can clean and scrape enough depth out....) and then cover with a layer of epoxy and glass cloth...
But now that it's open I'm wondering...??
1. Can I just fill the hollowed out core with layers of glass and epoxy (no wood)...? or
2. If I cut the lip off (that forms the bildge panel opening) could I run some teak/cumaru/holly flooring panels ..."perpendicular" to the keel across the bildge side to side...? or
3. Just rebuild the sole with ply and keep the stock bildge panel covers...?
"Might as well take 'er out...If anything is gonna happen...It's gonna happen out there..."
"Captin Ron"
Squidd is offline
