SailNet Community - View Single Post - Battery location and venting.
post #20 of Old 02-24-2013
mad_machine
Sea Sprite 23 #110 (20)
mad_machine's Avatar
Re: Battery location and venting.
Originally Posted by Minnewaska View Post
Start batteries never draw down much, so aren't the same as a house bank. AGMs will take almost whatever charge you can throw at them. After running the house bank down, they will burn out your alternator while recharging without adding a voltage regulator for starters. Even the charge voltage to keep them healthy is different.
I'm not the pro, I only know enough that the differences are significant.
You are thinking I was running the Red tops things from the automotive places. I run hawker odyessy batteries and they make drop in marine application batteries that are AGM and deep cycle.
Art Haberland
In the end all that matters is how fully you loved, how gently you lived, and how gracefully you let go of things that did not belong to you -Buddha
mad_machine is offline
