SailNet Community - View Single Post - Getting ahead of myself
post #18 of Old 02-25-2013
JimMcGee
JimMcGee's Avatar
Re: Getting ahead of myself
Originally Posted by jimgo View Post
My plan is to take her out, test out the main and jib, make sure I can start the engine without much difficulty, make sure the batteries are charing properly when the engine runs, and make sure the lights work (which will be covered in the survey, but with my luck, one will blow right after the survey is complete). There are several pieces of electronics, including a radar system, that I'll need to play with, too, so I can get more familiar with them.
Other than those things, what would you check out on a shake-down?
Sounds like you have a good plan. Be present for the survey if possible and ask the surveyor lots of questions. Good surveyors are a wealth of information.
Get familiar with your chartplotter on the shakedown (if present) and check if there are up to date charts aboard. Are the instruments working, especially the depth sounder?
The surveyor should check the VHF but a radio check can't hurt.
Motor for no less than an hour. Take her up to cruising speed for a while. Back her down a 1,000 RPM's and cruise for a while. Try different speeds. Listen and feel what the engine is doing. At the end of an hour is she doing anything different, is she dropping revs? If she is the most likely culprit is dirty fuel or filters. Write down the filter numbers and buy spares.
After a couple of hours on the water go below and look for any signs of leaks from hatches and stanchions.
95 Catalina 30 Island Time
The sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is offline
