I am trying to make the most of the limited information my instruments can show.
What kind of information about the boat, course and wind do you rely on while racing? Boat speed, wind speed and direction, AWA, bearing to the mark…what else?
Which information do you watch all the time, and which do you occasionally glance at?
... But can sometimes send you the "wrong way"... Away from the next shift.
I think thru the water boat speed is important for trimmers and helmsmen, tactically a 'good ol' compass is what's going to help you see the shifts to maximize gains up and down the course (assuming we're not talking about AC level computerized instrumentation)
I race on the lower Hudson River where there is tidal current that can reach up to 2 knots. The VMG that shows on our GPS can be very helpful to figure out if you are losing or winning against the current.
That said, you don't have current that strong on the Chessy usually but the vector made good (VMG) can help you decide what to do.
Your speed over ground (SOG) shown by a GPS can give you an idea of how well your sails are trimmed. Good speed in the wrong direction is not really that helpful though.
I have not heard of vector made good.
I learned VMG was Velocity made good. it is however a combination of speed and direction so angle or vector does enter the equation
Isn't the minimum a good arrangement of tells on your sail and a stopwatch? How serious is your racing?
I don't do very serious racing, but I do try to get better at it. I usually get to the line half an hour before start so that I can figure out which is the favored pin and timings (based on current wind conditions) for getting there. That is why the stop watch is helpful.
Sailing the same boat time after time will help you get an idea of what AWA's it is fastest at. This is going to depend on sails and sail condition. A handheld GPS measuring VMG may help you understand that, but on a small race course I wonder if you'll find yourself looking at it during the race. We use the GPS for speed over ground measurements too. You don't need anything fancy here and our GPS is normally just reporting two things: speed over ground and current time. We don't have coordinates for marks programmed into the GPS because they move a little bit on every race.
A windex is helpful to double check what the tells are telling you, but it is nowhere near as useful or important.
Telltales on the shrouds are easier to see and just as effective.
I like having a Windex and do use it a lot and it's well worth the $40 plus climbing the mast. On the other hand I've had a lot of fun racing on boats that don't have them.
Agree with most of what's said here.
Compass
Kitchen timer with countdown mode to time starts
Speed thru water for trimmers
Close-hauled gauge is a great luxury tool for beginning helmsmen
Lots of cheap and easy things - mark and standardize your car positions, rigging, halyards, sheets, etc...and don't worry too much about the fancy electronics.
Our boat currently has only one instrument installed at the helm, which is not helpful for crew (even if it’s only to pay attention to depth while simply cruising around).
I plan to install a few extra displays over the companionway, and before proceeding, I thought I’d probe the collective expertise here to make sure I’m on the right track for our level of racing.
If you're adding repeaters for the data at the helm at the companionway, well and good... On our last boat the instruments were over the companionway.. we (I) found it frustrating when crew (often) stood/sat in the companionway blocking the view from the helm....
Because I have an autopilot with a heading compass, I get a lot of good info regarding current and drift...which is factored into my COG (course over ground) readout. By calculating the difference between Magnetic compass heading and the COG, I can usually figure out if we're getting into the gulfstream or fighting eddys.
Its always good to know your tack angles factoring in COG
Related Threads
1.7M posts
173.8K members
Since 1990
