SailNet Community - View Single Post - downwind sail for PSC31
post #19 of Old 02-28-2013
knuterikt
Re: downwind sail for PSC31
Originally Posted by RainDog View Post
This is basically a spinnaker halyard problem. You will have it with any spinnaker arrangement unless you are going to use the same halyard for your genoa and spinnaker.
The normal solution is to install a Spinnaker Bail at the masthead. If you have the LeFiell mast you can get one here:
Masthead Assemblies
And using the genoa halyard is not a good idea.
Picture of the head of the asymmetric with the top swivel
tack of the same sail
The furler on the bowsprit without sail, the 1:2 tack line led back to the cabin top winch so I can adjust the tack hight and pull the furler out.
The sail get attached to the furler before the furler is attached to the tackline.
Close-up with the furler in position for the solent jib.
Flying the sail with tack eased
knuterikt is offline
