SailNet Community - View Single Post - Tips on Watch Standing
post #6 of Old 02-28-2013
SteveInMD
Re: Tips on Watch Standing
Very nice write up. I like to stay busy on watch; it just helps keep me alert. A few minor things you may possibly want to consider...
I'd like to see a few more checks regarding sail trim. It's easy to neglect checking for proper sheet trim, traveler position, backstay tension, halyard tension, vang, cunningham, leach lines. (Perhaps modify - If the wheel is over 90 degrees or more can you drop the traveler or do you need to reef?)
Do you monitor the VHF? If so check for proper adjustments periodically. Unless there is an electrical storm near by you should hear nothing out there. If you do hear someone, you know you have traffic nearby!
Are there any minor repair jobs that can be done while on watch? Whipping line ends, etc.
Occasionally ask your what you might do in an emergency. This could be anything from a squall line to a man overboard. You don't have to drive yourself nuts with these but it's worth some forethought. If you have SOPs for these, do remember what they are?
And lastly - Do I have any tips to add to the watch standing tips sheet!
SteveInMD is offline
