SailNet Community - View Single Post - Propane or alcohol
post #29 of Old 03-01-2013
boatpoker
Dirt Free
boatpoker's Avatar
Re: Propane or alcohol
From BoatUS website ...... they do mention one propane fire but that is only to be expected when you use a non-approved portable unit on a boat.
Causes of Fires Started Aboard
Click on the links below for more information:
1) AC and DC wiring/appliance - 55%
2) Engine/Transmission Overheat - 24%
3) Fuel Leak - 8%
4) Miscellaneous - 7%
5) Unknown - 5%
6) Stove - 1%
Stove fires appear to be less common (1%) than in the past, probably due to fewer alcohol stoves being installed on new boats. Still, alcohol can be a dangerous fuel; though it can’t explode, an alcohol flame is hard to see. One fire was started when a member tried to light the stove and gave up because he couldn’t see the flame. Unfortunately, he had succeeded, but didn’t realize it until he got a call from the fire department. Only one fire was started by propane; a portable stove fell off a counter and ignited a cushion.
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
