SailNet Community - View Single Post - Diesel fume barrier for master berth?
post #2 of Old 12-27-2006
erps
the pointy end is the bow
erps's Avatar
Been there. If there are no exhaust leaks or fuel leaks there should be very little odor. We had that problem and tracked it down to a small fuel leak. A little diesel fuel on a hot motor vaporizes and stinks up the boat. So I would look for leaks and fix them. Another strategy that we used was to run the bilge air blower while running the motor and for a little while after shutting if off to move a lot of fresh air through the engine compartment.
Those things either worked, or we got so used to it we couldn't smell it anymore.
erps is offline
