SailNet Community - View Single Post - damage after impact
post #22 of Old 03-02-2013
boatpoker
Dirt Free
boatpoker's Avatar
Re: damage after impact
Originally Posted by R&J View Post
Attachment 13505
Attachment 13506
It does look like of separated 'tabbing' caused by hull flexing, between the hull liner and the hull and the keel bolts have no rust, I will post a picture for more reference.
There is no "tabbing" or "taping" on the vessel under discussion. The liner is glued to the hull with a bonding putty. I'm not complaining about semantics, there is a substantial difference.
Taping or tabbing failure is readily apparent while the putty bonded liners have many bond areas which are simply not accessible without cutting the liner. Photo below shows a 2' X 2.5' section of liner cout out with the putty bead intact .... the liner had never made contact with the hull right from the factory. The liner was basically floating inside the hull and the entire boat was coming apart.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
