SailNet Community - View Single Post - survey tips wanted for ontario 32
post #2 of Old 03-02-2013
Faster
Re: survey tips wanted for ontario 32
What year? These are good cruising boats for our area but as ever, all the typical issues need a careful eye.
Loose stanchions often mean water intrusion below and the resultant damage.. is it a stanchion over a living space/locker or in the cockpit region.. often the ones near the cockpit get a harder workover esp if they are on un-reinforced gates.
The anchor locker lid underside is likely an easy fix, but try to figure out how that happened..
A running engine is a good thing, an overheating history not so much, if the engine has no aluminum parts it's less of a concern... however an extra close check/mechanical survey might be in order for peace of mind.
Wet decks are always a concern on cored deck boats, this one's no exception.
Best of luck... nice cruiser if everything pans out.
Faster is online now
