SailNet Community - View Single Post - Downside to leaving outboard motor prop in water?
post #8 of Old 03-02-2013
ChuckA
ChuckA's Avatar
Re: Downside to leaving outboard motor prop in water?
Originally Posted by PaulinVictoria View Post
If you sail? Yes, if you motor, probably not
Make sure the zincs on the leg are good and you should be fine.
Actually, you should expect it will grow a beard even if you motor. Guys with fast outboard & sterndrive powerboats also complain they can't keep the growth off their lower units even with antifouling paint. Periodic cleaning is probably the best you can do. Hopefully you can get at it easily with a brush either from the well, or with a snorkel. If you are in warm, high growth waters, you may have to scrub it weekly. If you do choose to paint it check the paint for compatibility with aluminum.
Best,
ChuckA
sailing a P28-1 Heart of Gold on Narragansett Bay
Twitter: @CoastalCafe_NE
ChuckA is offline
