SailNet Community - View Single Post - Blisters on survey - Morgan 38
post #4 of Old 03-03-2013
Gladrags1
Sailor
Gladrags1's Avatar
I'm thinking that the answer to whether you walk depends upon the costs for the repair and whether you can renegotiate the final selling price based upon the results of the survey. Some thoughts:
Cutless bearings all need to be replaced sometime. While it isn't an enjoyable job, it might be one that you can manage yourself depending upon your skill with mechanical stuff.
Bent blade on the prop; how bent? Sometimes you can repair it. Take it to the prop shop for an evaluation.
Does the rudder have to be removed to replace the shaft? If so, the marina would have to pick up the boat to drop the rudder and you start running into more $$$. If not, replacing the shaft isn't too onerous.
The blisters mean a bottom job with peel and re-epoxy. That can be expensive. The person who posted above asked a good question; are the blisters at or close to the waterline? If so, it might have occurred because the boat might have floated below her lines and the PO raised the waterline. The side of the hull now wetted may not have been protected by an osmotic barrier. Maybe the "bottom job" can be confined to the strip of hull near the current stripe? Talk with an expert and get some prices / options.
How bad are the leaks in the engine? I assume you are referring to the transmission seal? Cost / necessity of repair?
This is a "buyers market" and the seller knows that these problems will impact any possible sales. I would get prices for repairs and attempt to renegotiate based on what they are. The surveyor had to come up with a value for the boat. How close is the value and the selling price? If the boat is in as good of a shape as you report, these items shouldn't be a deal breaker necessarily.
Morgan made a good, solid boat. The "bones" should be good. Good luck with your decision.
Tod
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is offline
