Old 03-03-2013
magicmoments's Avatar
magicmoments magicmoments is offline
magicmoments is on a distinguished road
Re: General discussion
Wasn't that bad in my A plan, Just remove the back of the hanging locker to access the vented loop and cut the hose into short pieces with a jig saw. When I installed the new hose I put a ball valve in line to allow for easy head repairs.
For the tank to deck fitting I had to crawl behind the engine to pull it through and guide it up. I got lucky at the deck fitting as mine is on the coaming and by removing one of the storage bins I could reach in and access the tail of the deck fitting.
Use the best hose you can get for the tank to head section to avoid odour and doing the job again.
" I get by with a little help from my friends "
