SailNet Community - View Single Post - Blisters on survey - Morgan 38
post #10 of Old 03-03-2013
chef2sail
chef2sail's Avatar
Re: Blisters on survey - Morgan 38
Prop shaft, cutlass bearing would be less than $800. Parts are only about $300, Propeller repair,,,depends. If you ahve the prop shaft done either spring for a PSY driples ( anouther $300), and if not have the stuffing box looked at and replace the rubber stern tube. All part of the labor of pulling a shaft. We had the above done with PSY installed and new coupler for about $1000 last summer.
Blisters are another issue.
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is offline
