SailNet Community - View Single Post - Charging time and charger output
post #14 of Old 03-03-2013
Maine Sail
Maine Sail's Avatar
Re: Charging time and charger output
Originally Posted by outbound View Post
so basically fast charging is like the de sulfatization setting on some smart chargers? How about rate of discharge? Does running high load devices separately or together matter? In past always tried to avoid running them together if possible. Is that wrong?
It really depends on what batteries you have. Thick plate deep cycle batteries don't tend to deal as well with high loads as other types but this is more of a voltage drop issue to the equipment than overly detrimental to the batteries. Any load above your banks Ah capacity corrected Peukert will result in less Ah than the bank is rated for but a good battery monitor will keep track of this.
______
-Maine Sail / CS-36T
Maine Sail is offline
