SailNet Community - View Single Post - Spinnaker Pole Rigging
post #13 of Old 03-04-2013
Faster
Re: Spinnaker Pole Rigging
Originally Posted by svHyLyte View Post
Faster--I think the only difference between our descriptions is the vernacular. What you are calling a "downhaul" in our vernacular a "foreguy", i.e. a guy tacked forward of the mast verses an "after-guy", or guy tacked aft of the mast. If you look at your own illustration you'll note that the line leading to the lower bridle is identified as a "foreguy", Non?
Oui .... For me a foreguy is part of a dip pole setup with double sheets and guys.. Here the pole lift and foreguy both terminate at the tack end of the pole, and all tip loads are managed and balanced there. There is no bridle in that case.
So yes, they both hold the spinn tack 'down, but despite the mixed up terminology I think the end-for-end pole uses a down haul, and dip pole uses a foreguy....
Faster is online now
