SailNet Community - View Single Post - Navigation / Communication / Weather for Bahamas Cruise
Old 12-28-2006
camaraderie's Avatar
camaraderie camaraderie is offline
moderate?
Originally Posted by Pelham
So let's start with communications: I was originally thinking SSB ...
As an alternative - would renting a Satphone (Globalstar) suffice for emergencies? And would you think I'd need to rely on it for weather data as well? If so, what's the best method of getting weather data using a satphone, and what should I estimate my costs to be on that (#minutes/day)? This helps me decide satphone vs. SSB
You don't need an SSB but I would recommend renting a Sat Phone or buying a used one with a limited minute plan. The reason I recommend it is that the range of VHF is 25 miles or so and there is not always someone listening within range when you are crossing or making passages within the Bahamas. You need a reliable way to call for help if you have an emergency. You do NOT need one for weather if your trip will be to either the Abacos or Exumas as there are DETAILED morning weather and info nets on the VHF every day. Furthermore, there is both wireless and plug in internet in all the populated areas where you can easily sign up for a month of service. So...unless you plan on hanging out far from the crowds you don't need the added expense of data connections for your Globalstar.
I was thinking of a NavTex NX300 for receiving weather data...
Not needed.
For navigation - I know about the Explorer chart book for the Bahamas. Is an electronic chart plotter something we should be considering? Or will we be ok with some paper chart in the Gulf, the Explorer chart books for the Bahamas, and fleshing that out with some electronic charts from NOAA on the laptop?
Chartplotters are nice to have but completely unnecessary for safe navigation in the Bahamas. Indeed, many of the electronic charts that are available for the area ARE unreliable as they are based on old data and not up to date surveys like the Explorer charts. You will need a reliable GPS ...and I suggest that on your planned routes, you use the Explorer Chart waypoints to build GPS routes and enter them in advance of your trip so they are there when you need them.
Just as an FYI, we do have a GPS (and a backup handheld), but its a basic one - nothing fancy.
Do you know how to enter waypoints into both units?? Better yet...do it before you leave and be prepared for failure!Bring plenty of batteries...they are expensive over there.
Lastly -- Radar. We don't have it, and don't really need it in Mobile. For a trip like this, would you consider it an essential (or highly recommended) piece of safety equipment, or just a luxury we probably can do without?
A luxury you can do without. There is little traffic once you cross the stream and that only requires a good lookout for 8 hours or so. There is no fog to deal with.
Pelham
FYI...There is a good Abacos bulletin board with both sailors and locals that can answer many of your specific local questions..".i.e. where is internet access in Hopetown"...http://www.cocotels.com/
There is also a link to barometer bob the weatherman there so you can see the type of info you'll have easy access to.
