SailNet Community - View Single Post - Raymarine transducer sense wire (-RAYA 7pin connector)
post #4 of Old 03-06-2013
Classic30
Once known as Hartley18
Classic30's Avatar
Dock
Re: Raymarine transducer sense wire (-RAYA 7pin connector)
Happy to help.
Originally Posted by Alex W View Post
The e7d seems to want to see something on sense to know that a transducer is connected. I will do more tests and report back.
That's entirely possible.. It should be sufficient to connect Pins 5 & 6 together in the back of the connector and leave it at that.
EDIT: FWIW, if your transducer is a 300kHz unit and the E7 is transmitting at 200kHz, although it might work happily, don't expect the depth reading to be all that accurate..
Classic30 is offline
