SailNet Community - View Single Post - Zinc Or Aluminum Anodes On Mid Chessie
post #6 of Old 03-06-2013 Thread Starter
swampcreek
swampcreek's Avatar
Re: Zinc Or Aluminum Anodes On Mid Chessie
OK, I believe I have it down. On the Chesapeake from the head to just North of Baltimore is considered "fresh". Then there are 3 stages of brackish below that point. It is Oligohine where the salinity is .5 to 10 ppt (parts per thousand) is from north of Baltimore to the Bay Bridge. It is Mesohaline (salinity 10.7-18.0ppt) from the Bay Bridge to the Rappanannock (medium salinity). It is Polyhaline (18.7-36ppt) from the Rappohannock to the ocean (36ppt is ocean water). So if Aluminum alloy anodes are made for brackish water the Chesapeake is definitely the place to use them. Also, I read a zinc anode can form a layer of zinc oxide insulating itself, then the protected metal will deteriorate. So upon reading this I've ordered all aluminum alloy anodes (Non Chinese) and will put on our boat. I've used zinc my whole boating history on the bay, I wonder how much easier some of those outdrive and lower unit tear downs would have went if they were protected with Aluminum alloy anodes. BTW its aluminum ALLOY so this anode is less noble than straight aluminum.
This is a change of thinking and might seem strange but I remember seeing that first computer at work and thinking "Yeah, that'll be out of here soon".
2000 Catalina 320
Previous:
1993 Macgregor 26S
1981 Hobie H16
19?? Sol Cat
19?? Penquin
Many, many power boats
Life should be an adventure, not a guided tour!
Not all of us in the herd are sheep.
swampcreek is offline
