Slip size and boat size. - SailNet Community
Advertise Here
Go Back   SailNet Community > Welcome to Sailnet > Announcements, Suggestions Box and Site Issues
Announcements, Suggestions Box and Site Issues Forum tech support line. Problems with the site to report can be posted here.
Old 09-02-2010
rikbass is on a distinguished road
I have a boat slip which is 8.5 feet wide and 26 feet long. Draft is 3 feet at MHT.
What size (length) boat will fit in this slip?
  #2
Old 09-02-2010
rmeador is on a distinguished road
What kind of answer are you looking for? I'm pretty sure any boat that is less than 8.5 feet wide, less than (or maybe even slightly greater than) 26 feet long, and has less than a 3 foot draft would fit...
Does MHT mean "mean high tide"? I'm not familiar with that abbreviation. Hopefully it means the shallowest the water ever gets, since that would likely be your limiting factor. With such a shallow draft, you may be looking at a barge as the only thing that will fit
  #3
Old 09-02-2010
Yes, Mean High Tide. Low tide drops about down 1 to 1.5 feet.
Answer I am looking for is I can't seem to find research online as to beam width and lenght. Seems there should be a relationship. So a 7.5 wide beam boat typically runs what? 20 feet to 24 feet or what? Once I have a handle on this then I can narrow my search for a boat.
  #4
Old 09-02-2010
remetau's Avatar
remetau is on a distinguished road
With that shallow of water, I can't see any sailboat ever fitting in there. Maybe a shallow draft power boat, but even those draw at least 1 foot.
Don & Diana
sv Re Metau an HC33t
  #5
Old 09-02-2010
SecondWindNC's Avatar
SecondWindNC is on a distinguished road
Water depth is going to be your limiting factor, and you need to base it on the low tide depth, not the high tide depth; otherwise you'll be stuck looking at your boat sitting on the bottom, unable to get it out of the slip except at high tide.
As far as sailboats for that slip/depth, you're going to be looking at pretty small daysailors, probably centerboard dinghies, maybe a Hobie Cat. Going to be hard to find something with a cabin for water that shallow.
Carolina Wind Yachting Center, Washington, NC
Charters * Brokerage * Pacific Seacraft * Zodiac
Who is staring at the sea is already sailing a little.
  #6
Old 09-02-2010
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
The answer also depends on how much (if any) your marina will allow your boat to stick out beyond the end of the slip. Where I keep my boat (King Harbor, Redondo Beach) the limit is three feet, everything included. So a 25' slip can (in theory) accommodate a 28' boat. But, as was said above, draft is going to be your main problem. Could be worse, the tidal range in California is generally about six feet, eight feet during extreme Spring Tides.
  #7
Old 09-02-2010
CapTim is on a distinguished road
Maybe a smallish cat? a pair of sunfish might be fun...
... or I'm wrong.
Living aboard, currently in the Chesapeake
O'Day 37, still new to us
  #8
Old 09-02-2010
hellosailor's Avatar
hellosailor has a spectacular aura about hellosailor has a spectacular aura about
Rik, if you have your own private slip, whatever you can fit in it is what you can put in it. If it sticks out two feet over your yard, that's your business.
If "your" slip is part of a dock-o-minimum or other association, you'll have to consult the deed and association rules. Overhangs may not be allowed.
Offhand I'd expect a "not more than 26-foot-er" with a centerboard or a lifting keel, so it could squeeze into three feet of water. You'd need more than four feet at dead low tide to stick even a typical 24' sailboat in it, so a centerboard or other lifting keel is going to be crticial for you. Unless you're looking for a powerboat.
  #9
Old 09-13-2010
casioqv's Avatar
casioqv is on a distinguished road
Are you saying your slip is only 1 foot deep at the lowest tides?
That's not a boat slip- that's on the beach! If the bottom is soft mud and not rocks/coral you might be able to find a beachable boat, which won't be damaged sitting on the bottom. Even most small swing keel sailboats draw more than 1' with the keel retracted.
  #10
Old 09-13-2010
A foot deep?
Maybe a Boston Whaler. How did you come into possession of something that shallow? Win it in a poker game?
You may post attachments
You may edit your posts
Interesting Sailboats PCP Boat Review and Purchase Forum 6658 13 Hours Ago 06:28 PM
1979 C&C 29 Mk1 stuffing box flax size? dreuge C & C 1 08-25-2010 01:39 PM
2010 Delivery of s/v Felix sailingdog General Discussion (sailing related) 28 08-08-2010 11:13 AM
The question of ages - what boat? vtsailguy General Discussion (sailing related) 9 08-04-2010 08:54 AM
with a tiny boat; new to sailing surelyujest71 Introduce Yourself 5 08-04-2010 12:08 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
