Gel coat microcracks - SailNet Community
Advertise Here
Go Back   SailNet Community > Welcome to Sailnet > Announcements, Suggestions Box and Site Issues
Announcements, Suggestions Box and Site Issues Forum tech support line. Problems with the site to report can be posted here.
Old 06-18-2012
Aragorn47 is on a distinguished road
My 68 Ericson Crealock has microcracks on lots of surfaces. How do I repair or what to paint with to cover them up.
  #2
Old 06-19-2012
smurphny's Avatar
Over Hill Sailing Club
smurphny is on a distinguished road
Re: Gel coat microcracks
I have had this on two boats of that era, including the one I have now. There is no permanent
cover-up fix. I have tried a number of different approaches but nothing works as a permanent fix. You can epoxy prime with high-build but in a few years the cracks will reappear. The only way to really fix it is to sand off the gelcoat completely. Back in the 60s they did not formulate resins for the different expansion rates of gelcoat and underlying glass which is, as I understand, the reason for this. So, live with it, cover it up every few years, or start sanding
  #3
Old 06-19-2012
Jeff_H's Avatar
Moderator
Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about Jeff_H has a spectacular aura about
I spoke to both West Syetem and MAS Epoxy about this a few years ago. They both had suggested using a penetrating epoxy resin to saturate the cracks and then start with the various primers and paints.
My understanding is that there are basically two types of cracking, stress cracks which is generally a form of fatique and which will come back unless reinforced. The other form is a chemical break down of the gelcoat which occurs in gelcoats of all eras since gelcoat is unreinforced and made more brittle by the addition of pigment.
The problem is generally worse in the non-skid areas due to the variation in thickness but most visible on flat surfaces, like cabin sides. I like the sound of something like the KiwiGrip non-skid since it is slightly elastic.
Curmudgeon at Large- and rhinestone in the rough, sailing my Farr 11.6 on the Chesapeake Bay and part-time purveyor of marine supplies
  #4
Old 06-19-2012
smurphny's Avatar
I have tried all that. I think the problem must be that the cracks are so thin that there is no way to clean them effectively. If they could somehow be cleaned out with solvent so that a bond could be made with epoxy, it might be feasible. I have tried multiple soakings with acetone, soap, pressure, etc. Nothing seems to be able to get down into those microscopic fissures to get them clean. I've tried squeegeeing in West, different primers...all ineffective in a couple of years. I did my decks with Kiwi, which is incredibly tough stuff and have just noticed this spring that some hairline cracks are appearing in that now after 3 years. It seems like the only real fix is to sand off the gelcoat which is a job I don't have the motivation to tackle just for appearance sake.
You may post attachments
You may edit your posts
Bottom paint over Gel Coat without Barrier Coat? WagTheDog Gear & Maintenance 17 07-15-2012 07:33 AM
Gel Coat weephee General Discussion (sailing related) 11 03-22-2010 01:42 AM
Epoxy Barrier Coat over Gel Coat? lizardheadone Gear & Maintenance 2 01-17-2010 08:52 PM
Gel-coat pro in the NE SteveInMD Gear & Maintenance 0 05-27-2009 12:49 PM
gel coat dm567 Gear & Maintenance 15 01-02-2007 11:55 AM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
SEO by vBSEO 3.6.1
