down angle transmission - SailNet Community
post #1 of 5 Old 07-15-2013 Thread Starter
I am buying a new yanmar engine that according to the seller could come with an 8 degree down angle transmission. The engine that I took out of my boat had a 7 degree down angle transmission. Shall I go ahead and buy it?
Can this problem be solved by tilting the engine or installing a rubber coupling? Please advice.
Thanks
Carlos
carengin is offline
post #2 of 5 Old 07-15-2013
T37Chef's Avatar
Re: down angle transmission
Someone correct me if I am wrong but that should be within the acceptable range using the engine motor mounts to bring it within the proper alignment.
Shouldn't the seller, I assume a dealer, be able to confirm this for you though
Shawn
T37Chef is online now
post #3 of 5 Old 07-15-2013 Thread Starter
The seller has told me that he can take care of that and has also assure me that he will send his technicians to take a look at my boat. But he wants to sell, thats his job and once the engine is in place and paid for there is no way back. Whatever problems from there on will be on my own. I just want to Know if there could be any problem associated with that mismatch.
Thanks a lot for your response.
Carlos
carengin is offline
post #4 of 5 Old 07-15-2013
T37Chef's Avatar
Yes, I agree that the "salesman" will do just about anything to earn your business You may consult an outside/neutral mechanic (pardon the pun).
If you post with more detail, (boat, year, and the engine) I bet you will get a better response, its likely someone here will have done it already .
Shawn
post #5 of 5 Old 07-15-2013 Thread Starter
My boat is a Beneteau First 32 1983 it originally had a Volvo Penta MD7B, I am repowering it with a yanmar 3YM20.
Carlos
carengin is offline
How much Angle in my spreaders? Juanra Introduce Yourself 1 03-13-2013 10:23 AM
Angle of Spreaders casey1999 Gear & Maintenance 4 09-28-2011 03:25 PM
Best angle to windward? malyea Racing 9 12-07-2010 02:46 PM
Spreader angle? russ1302 Newport 9 06-22-2007 09:32 AM
Vang Angle T34C Gear & Maintenance 2 01-02-2007 09:44 AM
