10-23-2009
smackdaddy, when you get in a cab or a friend's car and see a flat tire, do you COMPLAIN ABOUT IT? Or just point it out because you know there's a problem going to get worse and affect everyone?
When you get on a boat and see spinaker lines run improperly, guaranteeing there will be a bad hoist, a lost race, and a torn chute, do you COMPLAIN ABOUT IT? Or just point out there's a problem?
There's a problem here at Sailnet. Some of the web coding is done improperly, resulting in improper displays and loads. I can tell that much just by watching how some of the pages load images before they move to the correct position, no need to unravel whatever coding was done. In the past ten years "proper" coding has been very much a moving target and it is much less common than folks think.
Eventually, the major players all update their browsers and the improper code simply stops working, and the "customers" just go away. ost web viewers will wait 15 seconds or less for a page to load and load properly--and if it doesn't, they just go elsewhere, without saying a thing. Not my opinion--there used to be a lot of research done like that on web design.
So, YOU'RE COMPLAINING. Some of the rest of us are calling for a little maintenance. And what you probbaly don't understand, is that given modern web tools, "a little" maintenance could mean hours and hours unraveling a multi-layered mess and a very expensive site remake.
