Endeavour 40 shower sump - SailNet Community
post #1 of 4 Old 09-18-2009 Thread Starter
Question Endeavour 40 shower sump
I am currently replacing the sole on my Endeavour 40. When I tore up the sub-floor I knoticed a container with some kind of pump attached. I was to find out that it was my shower sump. By the looks of it, it hasn't worked in quite some time. The shower runoff must have been over flowing into the bildge. Since this has been working for awhile, would it be ok to elimate this sump and just let the shower water go into bildge and be pumped out there.
eskimo1941 is offline
post #2 of 4 Old 09-18-2009
You could let your shower run into the bilge but after a bit it is likely to get a bit pongy, I would reccomend you fit some sort of sump to collect the water so it can be pumped overboard, it is possible to get an off the shelf sump with a pump allready fitted. I saw one the other day for about 80.
Cheers Jamie
cacique1977 is offline
post #3 of 4 Old 09-18-2009 Thread Starter
Thanks for the reply. I think I'll look into that. Since I have the sump uncovered anyway, now would be the time to fix it.
post #4 of 4 Old 09-18-2009
Waiting For Spring
krozet's Avatar
Your right, good time to fix it now. Do you want your bilge pump getting soap, hair and other goop in it on a consistent basis?
krozet is offline
shower sump- catalina 30 capttack Gear & Maintenance 0 08-19-2004 05:50 AM
Grooming Underway Joy Smith Her Sailnet Articles 0 08-26-2003 08:00 PM
Updating Your Head Sue & Larry Gear and Maintenance Articles 0 12-25-2002 07:00 PM
A Deep Sump Tom Wood Gear and Maintenance Articles 0 02-22-2002 07:00 PM
Installing a shower sump? AndrewB Gear & Maintenance 4 10-09-2001 07:31 AM
