Go Back   SailNet Community > Welcome to Sailnet > Announcements and Suggestions Box
  #11 (permalink)
Old 03-09-2010
k1vsk will become famous soon enough
Like many things, this is largely a matter of opinion - there is no absolute answer to the issue of paralleling multiple batteries being good or bad.
There are some fundamental considerations which should influence the decision more than the fear of a shorted cell:
Would you rather lift, move or replace large 8Ds or smaller 6V batteries?
Will one bad cell lead to a total power failure or do you have a spare/emergency power source?
How unlucky are you?
  #12 (permalink)
Old 03-09-2010
Bene505's Avatar
Glad I found Sailnet
Bene505 will become famous soon enough Bene505 will become famous soon enough
Following the spirit of the more advanced theme of Architeuthis' post, I often think that there's a place onboard for Edison batteries as part of the total capacity on board. Yes, they lose 1% of their capacity every day (and DON'T EVER OVERCHARGE THEM), but they last virtually forever. There are Edison batteries that are 50 years old still working perfectly.
The way to do it would be to figure out your daily usage, the amount you draw down on your lead-acid batteries each day. Then use Edison batteries for that load and keep your lead-acid batteries protected from any discharge cycles on typical days. The lead-acid batteries will last for decades, depending on how much you do draw them down. And since only the typically-used portion of your bank is Edison batteries, you won't be appreciably impacted by the 1% loss per day drawback.
Edison batteries are what the WWII subs used to provide power when underwater. They were also used by railroads.
Regards,
Brad
  #13 (permalink)
Old 03-09-2010
Architeuthis is on a distinguished road
Originally Posted by Bene505 View Post
Following the spirit of the more advanced theme of Architeuthis' post, I often think that there's a place onboard for Edison batteries as part of the total capacity on board. ...
Oh yeah! I would love some of those but as I recall cost and size work against them, banks get very large and heavy compared to lead acid. They also outlive the equipment they power so industry is not that keen on them.
But heavy is not so important in a boat so might be worth it if designed in.
The only ones I've seen have been when they are removed from old equipment. Some of those are dead so they can be killed but some were still kicking after decades in use. You don't see much of that these days.
Have faith that the oceans are going to rise and flood the world, that plague and pestilence brought on by Climate Change is going to punish us for not believing. Please do as they say it is our only hope. :P
Paralleling Batteries dave.verry Gear & Maintenance 79 11-27-2006 11:19 AM
Making Amps Shack Gear & Maintenance 18 09-23-2006 09:02 AM
