Another bit of malicious code on your site. - Page 2 - SailNet Community
 1Likes
post #11 of 23 Old 12-01-2011
Sunsets and Warm Beer....
LandLocked66c's Avatar
Interesting, I haven't seen anything. Although I run linux software appliances at the house to protect me with "real time" scanning.
You can't steer a boat that isn't moving? Just like a life - P. Lutus
LandLocked66c is offline
post #12 of 23 Old 12-01-2011
tdw
Super Fuzzy Moderator
tdw's Avatar
What do you for the scanning ? I'm running Linux Ubuntu at home and have yet to find a Linux scanner. (or am I misreading you post ?)
Cheers
Andrew
Andrew B (Malö 39 Classic)
― Terry Pratchett.
tdw is offline
post #13 of 23 Old 12-01-2011
Cheers
Andrew
I run an Untangle server as well as pfsense. There are a lot of great distro's out there. The Untangle server is transparent and filters what comes in and also blocks bad sites, adware, malware and so on along with a ton of other options. The pfsense is my firewall as well as partial blocking and a transparent web proxy to speed up my browsing. The difference is truly amazing. All you need are some old machines to run these on along with two nic cards per box.
tdw likes this.
post #14 of 23 Old 12-02-2011
tdw
tdw's Avatar
Thanks muchly though I confess I need to do some homework before I fully understand.
― Terry Pratchett.
tdw is offline
post #15 of 23 Old 12-02-2011
Originally Posted by landmineop View Post
The only information from Norton is as follows: Rule "Default Block SSP" blocked (10.0.0.23, Port(2869) ). Inbound TCP connection. There wre several that hit all at once. Sure glad I have Norton.
That's like well imagine you had Norton for your phone. And Norton for your phone told you that it had blocked an incoming phone call from a telemarketer who was trying to scam you. It didn't necessarily save you from anything. Computers receive random incoming connections all the time just like houses receive solicitors. Often they're out scanning the Internet looking for some old piece of software to take advantage of.
Anyway, I don't think that message you got was related to Sailnet.
But where is the malicious code that someones AV software is detecting? Is there an advertisement which is causing it? Did someone post a link to a malicious website in one of their postings?
CharlieCobra, I saw the fake Google link but where did that come from? Was it just added to a random place on the sailnet website? Or in an advertisement or someone's post?
steel is offline
post #16 of 23 Old 12-02-2011
Send a message via Yahoo to landmineop
The message I got was NOT from my phone. I was from my laptop. The message was taken directly from the Norton 360 that I use. The ONLY time this has happened is when I am on Sailnet looking at "new posts". It has happened twice in the last few days. When I check Norton it shows several attempts blocked, one right after another. Your opinions that they were not related to Sailnet are way off base. Stick to facts not hot air opinions.
landmineop is offline
post #17 of 23 Old 12-05-2011
tdw
tdw's Avatar
This morning I received warning while viewing new posts that Malware Bytes had blocked access from this site which was thought to contain malicious code. Since then I've checked and found that this site appears on some fifty spam blacklists. Where the problem is coming from I do not know.
IP: 213.13.145.4
Decimal: 3574436100
Hostname: *.blogs.old.sapo.pt
ISP: PT Comunicacoes S.A.
Organization: PT Comunicacoes S.A.
― Terry Pratchett.
tdw is offline
post #18 of 23 Old 12-05-2011
Strange?
post #19 of 23 Old 12-06-2011 Thread Starter
On the hard
CharlieCobra's Avatar
It just popped a redirect to it, probably when a rotating ad ran.
Baggett and Sons Marine Restoration
The Landing at Colony Wharf
Bellingham, WA.
CharlieCobra is offline
post #20 of 23 Old 12-06-2011
Are you guys using AdBlock Plus?
Code D pepperrent General Discussion (sailing related) 9 08-24-2011 07:44 PM
code zero vs 150 genoa costaricanwannabe Gear & Maintenance 5 11-28-2010 06:29 AM
Malicious Script - Be Careful tdw Announcements and Suggestions Box 26 04-14-2010 06:08 AM
Code Zero configuration CodeZero General Discussion (sailing related) 4 08-04-2009 07:04 PM
