Up the mast on the hard? - SailNet Community
 4Likes
  • 2 Post By Faster
  • 2 Post By Faster
post #1 of 10 Old 03-08-2013 Thread Starter
ScottyG24's Avatar
Planning on doing some top of the mast maintainace with my bosuns chair as I like tobe in the water a d ready early in the season.Only times ive been up the mast has been with a boat in the water. The boat is a 1988 Oday 272LE sitting on the hard in a cradle. Is going aloft with the boat on the hard a no-no?
ScottyG24 is offline
post #2 of 10 Old 03-08-2013
Lake Superior Sailor's Avatar
Re: Up the mast on the hard?
I have been up mine on a trailer without trouble! Why not..Dale
Reluctant Lady
Cal 28, 1967
Lake Superior
Where God got it done!
Lake Superior Sailor is offline
post #3 of 10 Old 03-08-2013
Ask your yard manager... many yards may prohibit this.. personally I think it's a bad idea..
dacap06 and jimgo like this.
Faster is online now
post #4 of 10 Old 03-08-2013
Send a message via Yahoo to dacap06
I agree, this is a bad idea. Going up the mast in a bosun chair on the hard is not a good way to save money. This is why yards have lifts, bucket trucks, and what not. They'll get you up far more safely.
Tom
T. P. Donnelly
S/V Tranquility Base
1984 Islander 30 Bahama
Pasadena, MD
dacap06 is offline
post #5 of 10 Old 03-08-2013
T37Chef's Avatar
don't do it for all the reason stated and then some
Shawn
T37Chef is online now
post #6 of 10 Old 03-08-2013
bljones's Avatar
It is a deck stepped mast- with a gin pole and some assistance you can drop the mast and work safely in a lot less time than it takes to rig the chair and find someone willing to hoist you up and then back down to gather the gear you forgot, and then back up.
here's how:
Stepping Mast for O'Day 272? - SailboatOwners.com
It's 5 o'clock somewhere:
bljones is offline
post #7 of 10 Old 03-08-2013
On a boat that size, and adults weight is clearly an issue when in the water. On the hard, I believe you are asking for trouble. Just because someone pulled it off, doesn't make it safe.
Jeanneau 54DS
Minnewaska is offline
post #8 of 10 Old 03-08-2013 Thread Starter
ScottyG24's Avatar
My yard has no lifts or any equipment other than a tug to put the boat in thier cradles in and out of the water. its a real throw back to the do it yourself era. Assuming proper use of the bosuns chair with two halyards can i ask is the issue that the keel n hull are not in the water thus only supported by the four jack pads on the cradle and the keel on blocks? What im saying isexplain to me in engineering terms how it differs from going up with the boat in the water?
I weigh 155lbs
post #9 of 10 Old 03-08-2013
From this article (first google hit)
Working Aloft
This paragraph:
1. Do it while the boat is afloat. Most boatyards ban the practice of climbing the mast of a boat on the hard, and for good reason. A keel boat propped up ashore is defying gravity and your weight jerking around aloft can cause it to lose balance.
Thing is, if you somehow overbalance the boat afloat it will rotate around it's center of bouyancy and lean over... if you do it on the hard the boat rotates around the bottom of the keel.. if a stand slips, or your actions on the end of a 30+ foot lever otherwise compromise the delicate balance of a boat perched on the ground, you're going for a short (but nasty) ride to the ground, along with the boat.. and most likely trying to go through one or two neighbouring rigs too.
One average guy up the mast of a Formosa 41 in the hard?? maybe.. on a lightweight 30 footer? maybe too, but.....On a 25 footer I'd say no way...
dacap06 and Minnewaska like this.
post #10 of 10 Old 03-08-2013 Thread Starter
ScottyG24's Avatar
thank you
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
Installing aluminium mast steps on steel mast asivesind Gear & Maintenance 10 01-29-2012 10:05 AM
How to secure steaming light to mast with halyards inside mast. Eihli Gear & Maintenance 7 04-14-2009 03:11 PM
Deck Stepped Mast or Keel Steeped Mast??? tbeargladd General Discussion (sailing related) 36 11-14-2007 08:07 AM
up the mast on the hard maestro Gear & Maintenance 28 03-29-2006 07:19 AM
