True-Wind Calculator - SailNet Community
Apps & Authors This forum is specifically designed for authors, designers, and members to showcase their wares. These must be sailing related!!!
post #1 of 8 Old 02-09-2014 Thread Starter
Hi,
i am the author of the following simple app that you might find usefull.
It is named True-Wind Calculator and this is what it does:
True-Wind Calculator is an app that helps you calculate True-Wind direction and speed based on actual vessel speed, apparent wind speed, angle of apparent wind to the vessel and vessel heading.
App is currently available for iOS devices, but will soon be available for Android devices too.
Here is the link form iOS: https://itunes.apple.com/us/app/true...9613?ls=1&mt=8
You do not need interent connection to use it
Please share your thoughts with me.
Thank you for your attention and I hope you will find use of my app
nejcl is offline
post #2 of 8 Old 02-10-2014
SV Skalliwag #141
brokesailor's Avatar
Re: True-Wind Calculator
I was not able to find it on IPad.
brokesailor is offline
post #3 of 8 Old 02-10-2014 Thread Starter
Currently you can find it in iPhone section, but update will make it universial.
nejcl is offline
post #4 of 8 Old 02-11-2014
If the user must input the data:
wouldn't he need a windgauge or other instrumentation that would also provide true speed and direction already ?
"Just call me TB"
capttb is offline
post #5 of 8 Old 02-11-2014 Thread Starter
As i know not all instruments for wind are able to show true wind. Corrent me if i am wrong but i know couple users that have situation like this.
nejcl is offline
post #6 of 8 Old 02-12-2014
I'm only familiar with gauges that display true and apparent wind, you may be correct.
"Just call me TB"
capttb is offline
post #7 of 8 Old 12-15-2014
I am sorry that it is for IOS 7.0 and above. I use an ipod with a Dual GPS/battery slipcase on IOS 6.1.6.
jhastie is offline
post #8 of 8 Old 01-06-2015
I have downloaded the calculator...and tried entering some test examples. The calculation shows, for example, True Wind Direction 2.00 plus or minus 129.29. Is this an appropriate result???
Mallin is offline
Tags
app , calclulator , ios , true wind
Calculating true wind MarkSF Gear & Maintenance 11 01-24-2013 11:16 AM
ST80 Shows No Difference Between True/ Apparent Wind OffshoreDreamer Gear & Maintenance 8 08-03-2012 08:58 AM
True Wind vs Crazy Speed Transducer bacampbe Electronics 16 10-15-2009 11:17 AM
True Wind Speed and Direction SEMIJim Gear & Maintenance 34 12-01-2008 06:28 AM
HTML code is Off
