Yacht Question From Author - SailNet Community
Apps & Authors This forum is specifically designed for authors, designers, and members to showcase their wares. These must be sailing related!!!
 2Likes
post #1 of 32 Old 03-05-2014 Thread Starter
Hi everyone, I am an author writing a historical mystery and I am hoping you can all help me with a question. Although I've looked and looked, I have not been able to find out what the raised part of a deck is called (the top of the cabin). Here is the yacht I'm using as reference:
Gaff Rigged 41ft Cutter 1890 William Ferris William Ferris. Yachts sold by classic yacht broker..
One blog I came across seemed to indicate that it was the 'camber' but I've not been able to verify that.
Also, (1) would the ladder steps be referred to as the companionway? (2) As I understand it, the top of the surrounding railing is called the rail and the solid part the bulwark? Or is that only on larger ships? (3) And if two people were sitting on deck chatting while the boat is moored, where would be the likeliest place they'd sit (I'm assuming on the cabin top?)
Any help would be appreciated.
-Sabrina Flynn
Sabiny101 is offline
post #2 of 32 Old 03-06-2014
Re: Yacht Question From Author
The top of the cabin could be the cabin top.
Boredop is offline
The Following User Says Thank You to Boredop For This Useful Post:
Sabiny101 (03-06-2014)
post #3 of 32 Old 03-06-2014
I've been calling it a cabin top
benny241525 is offline
The Following User Says Thank You to benny241525 For This Useful Post:
post #4 of 32 Old 03-06-2014
I've also heard cabin bunk
post #5 of 32 Old 03-06-2014
I don't know the setting in your historical mystery, but I guess you have read the history of the boat.
She was converted to a "Cruiser" in 1913 and is a British built boat.
Boats from others parts of the world would have looked different.
Cabin top seems to be the correct term
companionway Ladder.
Correct.
In the Cockpit or maybe at the cabin top or maybe they carried small foldable chairs.
I would guess that it would depend of the weather / wind.
around 1900 and well into that century yachts like "LITTLE WINDFLOWER" often had payed hand(s) (aka crew).
They slept in the bunks forward and where not supposed to mingle with the owner and the guests.
The crew would often stay at the bow out of way for the owner/guests.
knuterikt is offline
post #6 of 32 Old 03-06-2014
I can't get the picture of the yacht in question to open.
It sounds like you are referring to the coachroof, which is the raised part of the deck that allow for a higher headroom inside the cabin.
Yes, the steps from the cockpit into the cabin is the companionway.
The raised area around the cockpit may be referred to as the coaming, although, most use the term to refer to an accent piece on top of what is the coaming.
People ordinarily sit on deck in the cockpit. Although, in some new boats this has been enlarged, as on ours, and the term 'deck salon' has been coined.
I hope I got the questions correct, I couldn't see the pic.
Jeanneau 54DS
Minnewaska is offline
The Following User Says Thank You to Minnewaska For This Useful Post:
post #7 of 32 Old 03-06-2014
Old as Dirt!
svHyLyte's Avatar
-Sabrina Flynn
The cabin-top is properly referred to as the "coach roof". Folks might sit on the coach-roof but, considering it's exposure, not too often. The rail around the stern of a ship is know as the "taffrail", sometime elaborately carved. The rail around the remainder of the ship atop the bulwarks is properly a "cap-rail". The entry to a yacht accommodation from the deck is a "companionway". There are no stairs on a yacht but if there are steps to the sole within the accommodation from the companionway, they are referred to as the/a "companionway ladder" (there may be more than one). People might sit together anywhere on deck but are most often found in the cockpit where they likely have some sun protection and can lean back against the "combings" that commonly extend aft from the sides of the coach-house on either side of the cockpit and are intended to deflect seas that make it on deck away from the cockpit crew.
FWIW...
bljones and Atlas like this.
svHyLyte is offline
The Following User Says Thank You to svHyLyte For This Useful Post:
post #8 of 32 Old 03-06-2014
Dirt Free
boatpoker's Avatar
The coach roof is more properly termed the "trunk" or "cabin trunk".
"Companioway steps/ladder" are commonly shortened to "companionway"
Suggest you check out the "Surveyors Lexicon"
or buy
The Sailors Word Book, Admiral W.H. Smyth, ISBN 1-897030-05-3
PS. Don't ever refer to a "salon", that will nail you in a heartbeat. the proper term is "saloon".
Be the man Sharon thinks I am - wg
I can do that
- wg
Be the master of your own disaster - wg
If you're not laughing, you're not doing it right. - wg
if you can live with the consequences, go for it. - wg
I yam what I yam an' thats all that I yam. - Popeye
boatpoker is offline
The Following User Says Thank You to boatpoker For This Useful Post:
post #9 of 32 Old 03-06-2014
rhr1956's Avatar
I agree..."Coach Roof" is the raised portion of the cabin providing interior head room on a boat.
rhr1956 is offline
The Following User Says Thank You to rhr1956 For This Useful Post:
post #10 of 32 Old 03-06-2014 Thread Starter
Thanks for your reply! The mystery is set in 1900 San Francisco. And the yacht in question is supposed to have been built by a local family of Portuguese boat builders in Sausalito as a sea going vessel. I'm mostly using the Little Windflower as a reference. Would a boat like this be described as a cruiser instead of a cutter then? And do you happen to know if these types of yachts had some kind of engine installed as early as 1890s? I know they had steam powered launches and such at the time period, but not sure in a boat like this.
And thanks for reminding me about my crew question. Would it be possible to single-hand a boat like this for a short trip? From the other forums and research I read, it seemed like it would be possible by an experienced sailor. And I read up on Joshua Slocum sailing the Spray around the world single-handed.
Historical question: toilet on small yacht? tiamore General Discussion (sailing related) 25 09-02-2016 01:35 PM
Question about VAT for non-EU registered yacht patrickstickler General Discussion (sailing related) 4 05-10-2010 07:05 AM
HTML code is Off
