Exhaust Elbow - SailNet Community
post #1 of 6 Old 07-18-2013 Thread Starter
PAULCR1's Avatar
Exhaust Elbow
I have a Universal 5432 and am in need of an exhaust elbow. Anyone have any ideas? Thanks
Theodore Roosevelt said “In any situation, the best thing you can do is the right thing; the next best thing you can do is the wrong thing; the worst thing you can do is nothing.”
PAULCR1 is offline
post #2 of 6 Old 07-18-2013
Islander Yacht Fan
ECS-IB30's Avatar
I've been working on our Islander Bahama 30 that had a very rusted exhaust elbow and wet riser. After disassembly I discovered the flange was threaded for schedule 40 plumbing pipe. I bought the pieces needed to get the best shape, cut a piece for the water outlet welded it up and painted it. Cheap and with some exhaust wrap quiet too.
ECS-IB30 is offline
post #3 of 6 Old 07-20-2013
JimsCAL's Avatar
Re: Exhaust Elbow
The Universal 5411 on my previous boat had the exhaust elbow made up from standard pipe fittings (elbows, tee, reducers, nipples). When it came time to replace it, a trip to Home Depot provided all the black iron parts I needed for about $30.
JimsCAL is online now
post #4 of 6 Old 07-20-2013 Thread Starter
PAULCR1's Avatar
Re: Exhaust Elbow
Thanks all for your inputs.
PAULCR1 is offline
post #5 of 6 Old 09-03-2013
Re: Exhaust Elbow
PAULCR1: Not sure what you ever did with your exhaust elbow but a recent issue with excessive heat on my elbow led to me unwrapping and seeing how it was put together. Very simple standard threaded pipe vs. the $200 westebeke elbow I have seen out there. Let me know if you want/need a picture and I will grab it. Very simple.
My big problem is that I have heat at this elbow that actually caused the muffler wrap to smolder and smell (that is hot). I plan on shooting temperatures to see what is going on and thus far have cleaned everything to ensure no back pressure (except for where manifold joins elbow)....and all this happens at 160F before a major over-heat. I am going to put post out on specific topic. Ever have this?
westerml is offline
post #6 of 6 Old 09-03-2013 Thread Starter
PAULCR1's Avatar
Re: Exhaust Elbow
Hi Westerml,
I had my existing exhaust riser welded and it has functioned fine since. However, it cost me $200 to have this done and after I found a new one on ebay for $80. Day late and a dollar short.
PAULCR1 is offline
Exhaust Elbow Lostmt Watkins 2 03-23-2013 08:19 PM
Where do I find an exhaust elbow leeisagenius General Discussion (sailing related) 2 07-24-2010 03:41 PM
2GM20F Exhaust Elbow thisisus Diesel 8 07-19-2009 06:34 PM
Atomic 4 Exhaust Elbow steich Gear & Maintenance 13 12-26-2008 06:57 PM
Exhaust mixing elbow I-33 Gear & Maintenance 2 12-02-2006 03:24 PM
