another tank cleaning issue - SailNet Community
post #1 of 13 Old 11-14-2013 Thread Starter
I've read probably all the way posts on the subject but still don't have clear solution (no pun intended). I have a 1971 Pearson 30 with a 1991Yanmar 2gm20f which probably has the old A-4 tank still in it. I know there is crud on at least the bottom, problem is, no inspection port and narrow, deep fill port only. The tank looks fine so don't want to replace, plus it would be a bear to negotiate it out and in. Some have implied getting a service to do it under these conditions but putting out one last shot at maybe someone finding a new solution. I probably can't jiggle a rag on a stick too much so my options are limited.
Any help appreciated.
alechich is offline
post #2 of 13 Old 11-14-2013
Re: another tank cleaning issue
Install an inspection port. In a previous discussion "Cutting Access Hole in Stainless Steel Diesel Fuel Tank" there was some valuable info. As usual on the forum, there was probably a bunch of half-baked suggestions also. The trick is to devine the difference.
Hudsonian is offline
post #3 of 13 Old 11-14-2013 Thread Starter
Thanks Hudson, you think this is better than just getting it cleaned, to hopefully last a few, five years? I will have to pay a pro to put one in in any case.
alechich is offline
post #4 of 13 Old 11-14-2013
jppp's Avatar
On a side note. Back in my diesel/veggie conversion days for my truck I remember galvanized tanks being unsuitable for diesel. If the boats tank was originally for an Atomic there would be no way the tank was galvanized, would there? just wondering. Gotta be aluminum or ss right?
1985 C&C 35 MK 3
jppp is offline
post #5 of 13 Old 11-14-2013
JoeLena's Avatar
I would doubt that tank is stainless. On my 72 Catalina is was not anyway. Monel was a popular choice then. Mine looked good on top, but once I poked around it was obvious it needed replacing. I ended up cutting it in pieces with shears. That was no picnic for sure, but great to get it out.
Lots of help on the Moyer Marine forum as well.
'72 Catalina 27 Tall Rig #519
JoeLena is offline
post #6 of 13 Old 11-14-2013
Delezynski's Avatar
Location: Currently in Az. and trailer to various places.
As was said, install a clean-out port. They sell ready made ones that are easy to install. You might also want to see my tank replacement web page. It has many photos of ours that sounds similar to yours.
Our page is at; Guenevere's Projects, Fuel tank replacement
Greg
Greg & Jill Delezynski
Nor'Sea 27, Guenevere
Home page -
Youtube page -
Youtube Virtual Reality page -
Delezynski is offline
post #7 of 13 Old 11-14-2013 Thread Starter
Ok, thanks to all. Here's the thing, I love my boat but I've shed too much blood and tears on it already, not going to go through tank removal unless absolutely necessary.
alechich is offline
post #8 of 13 Old 11-14-2013
One of None
deniseO30's Avatar
It IS necessary! (how do I know?) not a matter of if it will fail, but when.. and it will fail. Remove it and be done with it. "Looks ok" doesn't work either because the pin holes are nearly microscopic. Love your boat .. not your tank.
My last project!
deniseO30 is offline
post #9 of 13 Old 11-15-2013
ericirvine's Avatar
I can't argue with the wisdom of installing a good sized inspection port, it's the best way to go. On my own boat, while my engine was out I simply removed the tank and used a pressure washer and degreaser to clean the tank out. Simply stuck pressure washer wand in every orifice and rinsed till no more stuff washed out. No problems since reinstall and 20+ hours on newly rebuilt engine.
HTH
Eric Irvine
Bristol 29.9
"Selkie"
ericirvine is offline
post #10 of 13 Old 11-15-2013 Thread Starter
Thanks Denise and Eric, I'm not planning on removing my engine and if that's necessary to remove the tank I'll try any other option. No one yet has commented on tank cleaning services. ? Also why would I think there are pinholes if there is no evidence of leaking fuel? As indicated, the tank looks fine of what I can see of it (it rests partly in a wooden box) so why should I assume there are pinholes? The aluminum (I think) looks strong and I don't see or smell any evidence of fuel. The engine doesn't seem to use any fuel, I could probably cross the pond by power on one tank. (;
alechich is offline
PS34 Water Tank Issue stipakb Pacific Seacraft 4 05-17-2012 04:43 PM
Cleaning the Holding Tank LadyAV8R Gear & Maintenance 11 10-22-2008 12:18 PM
Huh? - fuel tank issue nunzio Gear & Maintenance 13 06-24-2008 12:04 PM
Update on SIYB hull cleaning issue Fstbttms Gear & Maintenance 5 04-08-2008 08:00 AM
cleaning out gas tank calomar Gear & Maintenance 6 08-17-2002 09:36 AM
