Leaking Heat Exchanger - SailNet Community
post #1 of 5 Old 06-02-2014 Thread Starter
Been noticing a small drip under the bottom of the bulkhead mounted heat exchanger. When I start the engine, it starts spraying a pretty decent amount. Is it possible to spot weld this part? I do not know how old it is.
Thanks.
FirstCandC is offline
post #2 of 5 Old 06-04-2014
Brewgyver's Avatar
Re: Leaking Heat Exchanger
Can you provide any info on the HE? It would be nice to know the manufacturer, but at the very least the material. A picture would help.
While not technically a spot weld, a brazed repair might be possible, depending on the material. Some people have had success using JB weld type epoxy for pinholes and small cracks.
s/v My Sweet Girl!
Catalina 30 (Mark I)
Atomic 4
Brewgyver is offline
post #3 of 5 Old 06-04-2014 Thread Starter
Thanks for the response. Third item down in the link below is the replacement part. Unfortunately, I do not have a photo of my current exchanger.
Moyer Marine Atomic 4 Engine Rebuilding and Parts
Probably going to just go ahead and buy a new one. Going to take the part off for a looksie this weekend. But I hope there isn't an underlying problem which is creating too much pressure on the HE? The oil looks good (and pressure is steady at 40) , temp has been good too (around 180). I don't think it is a head gasket problem.
post #4 of 5 Old 06-06-2014
Unless the body has gone porous with electrolysis a simple silver solder or braze can fix a fatigue crack or?? Too much heat can effect the tubes so careful.
Capt Len is offline
The Following User Says Thank You to Capt Len For This Useful Post:
FirstCandC (06-09-2014)
post #5 of 5 Old 06-08-2014
Take the heat exchanger to a radiator repair shop to have it pressure tested. When they determine where it's leaking they'll probably be able to repair it on the spot.
Hudsonian is offline
The Following User Says Thank You to Hudsonian For This Useful Post:
Universal M-18 Heat Exchanger engineer_sailor Diesel 17 05-25-2014 01:31 AM
Heat Exchanger Gasket? jballou Diesel 7 05-23-2014 03:14 PM
Heat exchanger Flfishindude O'Day 5 08-17-2013 10:07 AM
Heat Exchanger help DBboat Gear & Maintenance 14 05-20-2008 05:57 PM
heat exchanger Jovietal Gear & Maintenance 4 04-03-2007 04:59 PM
