Blogs
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Atomic 4
User Name
Old 05-05-2006
kurt crowley kurt crowley is offline
kurt crowley is on a distinguished road
Send a message via AIM to kurt crowley
prop shaft coupling
Can anyone walk me through the removal of prop coupling?
I'm removing the A4 while in the water.
have removed the three bolts and the set screw.
Do I pry out the half moon set screw next?
Thank you for any help.
Old 06-22-2006
biggestb biggestb is offline
biggestb is on a distinguished road
The set screw on my engine does not need to be touched to separate the two halves of the prop shaft coupler. The two halves probably just need a little "ecouragement" to separate. I have done mine twice simply by unbolting the 3 bolts. By the way, the half moon is called a Woodruff Key.
Old 06-27-2006
tenders tenders is offline
tenders is on a distinguished road
One way to do this is to place an appropriately sized socket at the non-propeller end of the shaft, use longer coupling bolts, and press the shaft out of the coupling by tightening the bolts and squeezing the socket between the engine-side coupling and the shaft inside the other coupling. This can be MUCH harder than it sounds. If you have three bolts on your coupling, it sounds like you have a V-drive. The longer bolts you use can't be too long or they won't fit around the shape of the coupling.
Sponsored Ad
vB code is On
Antifouling Prop & Shaft Foolishness323 Gear & Maintenance 9 12-07-2009 09:24 AM
prop shaft assy pmcandrew Gear & Maintenance 1 01-23-2005 04:41 PM
Paint Prop & Shaft nauticalrich Gear & Maintenance 3 04-04-2003 04:13 PM
prop shaft thomasstone Gear & Maintenance 3 03-27-2002 03:03 PM
prop shaft coupler thurston Gear & Maintenance 2 12-31-2001 06:00 AM
Page generated in 0.3986 seconds (46.25% PHP - 53.75% MySQL) with 15 queries
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
