Blogs
Go Back   SailNet Community > Special Interest Groups > Atomic 4
User Name
Old 04-07-2006
sailnaway sailnaway is offline
sailnaway is on a distinguished road
Atomic Is No Bomb
I guess I am the only guy who loves this motor well me and Dom Moyer oh and Indigo Inc. This little gas motor is easy to maintain. It will take allot of abuse and keep you running. I have pushed my 22.000 LB boat for over 7000 KM in three years. I use it to power my inverter and watch movies because its quiet enough to do this. I do have to keep up with the points and all that because I am to cheep to buy the electronic ignition which is sold by Moyer and Indigo. My motor is fresh water cooled always was so it has a little longer life than some salt motors. For the gas worry I run the blower and sniff after a few seconds of running the blower if no raw gas smell then fire the puppy up. I also have the electric fuel pump and all the manuals which are as simple as the engine maybe 65 pages total. This motor was built from 1946-1979 with some being sold a little later. some where around 48.000 were built and many are still around. a rebuild will cost nearly $4000 from Moyer much less if you can do it yourself. All the parts are aftermarket and can be had easily. The company is now Universal and builds the small diesel which you can put in place of this ATOMIC if you want. I like this engine and do not plan to re power unless I loose a rod through the block or something. They all came with the Tranny attached which is also simple straight forward and a reduction in reverse. Never pass up a good boat because it has an Atomic you will be pleased at what you will learn from the ATOMIC 4 groups and die hard ATOMIC enthusiasts like me. Thanks to Don Moyer and Indigo for the fine products and service they offer. The ATOMIC is no BOMB.
Old 04-18-2006
Henry Stafford Henry Stafford is offline
Henry Stafford is on a distinguished road
Re: atomic4 no bomb
I have an atomic 4 in my 1974 Ericson 27'. The impeller went to pieces and overheated the engine (to the point of discoloration). I did not see the temp guage since it was mounted on the inside of the cabin on the instrument panel. So I added a panel in the cockpit, moved the gague, and added a tackometer. Before I could replace the impeller a leak developed in a hose an put the motor under water. I had a tech who had worked on atomic 4s get the engine working again. The engine starts as soon as you hit the switch and runs fine. It appears it can not be killed no matter what happens to it. My problem is that the steel gas tank has crap in the bottom (probably rust) and there is a Fram "special marine" gas filter (FBM1110-PLM) that I can't find a replacement for. I would like to replace the gas tank with a plastic one and replace the filter that sits between the tank and motor. Any suggestions?
Henry Stafford
Old 04-18-2006
Jim H's Avatar
Jim H Jim H is offline
Jim H is on a distinguished road
As for your filter, could this be it:
http://www.shipstore.com/SS/HTML/FRA/FRAFBM1110PLM.html
Note that the replacement filter is linked at the bottom of the page, and costs about $7.50.
Thanks for the stories about your Atomic 4 "surviving everything." I've only had mine a short while, but it runs really well and I hope that it's as bulletproof as yours.
Jim H
Old 05-25-2006
captainbrad captainbrad is offline
captainbrad is on a distinguished road
Yes, this is a great little engine. It's simple, quiet, easy to maintain, and everything is easy to get to (well, depending on your boat too I guess).
The impeller incident Henry writes about is not uncommon. Same thing happened on my dad's old Columbia 31. One fin of the impeller wedged itself in the cooling system and essentially stopped all water flow. It didn't sieze, but it did require a major overhaul. I remember as a kid having one winter with A4 parts spread all over the basement :-).
3 key things w/ A4 impellors:
1) Always carry at least one spare and know how to change it at sea. If you want to make it easy on yourself, get one of those aftermarket kits with the thumbscrews and the quick release cover.
2) Change it every spring religiously. Doesn't matter how much you used the boat last year, just change it. If you didn't use it much, keep the old one as a spare, but mark it with a tag as limited lifespan spare only.
3) Install a simple temp and oil pressure alarm. I found one at Boat US for under $20. Very easy to wire and install. Put the buzzer where you can hear it from the helm, and maybe wire a light to it as well. That way if the engine does begin to overheat, you'll know hopefully before any damage is done.
Othewise this is a great engine. I've got mine running so well that it'll idle at about 100 RPM IN GEAR!
This is always a good resource if you have questions or problems with your A4.
-BRad
Old 05-25-2006
mschwarz mschwarz is offline
mschwarz is on a distinguished road
I'm another atomic fan! I have the Atomic 4 in a 1961 Pearson Triton (hull #229) that has been a work horse for many many years. Moyer rebuilt her in 2001 and the few upgrades that were added make her better than ever. We just put this '61 Pearson Triton up for sale due to our finally being able to afford something bigger, but we'll miss that dependable motor!
Mike Schwarz
Prior Owner of Beneteau 323 (#101)
(sold in 2007)
sailstellablue@yahoo.com
Old 06-04-2006
russell32 russell32 is offline
russell32 is on a distinguished road
After some research, I decided to replace my Atomic four with another A-4 takeout. The mechanic doing the installation assures me the takeout is a good motor and it should bolt right in. People on the dock come by and offer advice and encouragement regarding the A-4. Wish me luck!!!
Display Modes
vB code is On
HTML code is Off
Atomic 4 fuel economy grumol Gear & Maintenance 6 12-05-2006 02:14 PM
Thermostat for Atomic IV owlmtn Gear & Maintenance 5 07-31-2005 01:34 PM
water in crank case - Atomic 4 Reesser Gear & Maintenance 2 07-03-2005 08:52 AM
Atomic 4 replacement mr.fixit Gear & Maintenance 4 06-16-2005 04:48 PM
Atomic 4 Studs TerenceONeill Gear & Maintenance 2 04-06-2003 11:12 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
