Compression test w/o closing thru-hull water - SailNet Community
Blogs
Go Back   SailNet Community > General Interest Forums > Gear & Maintenance > Atomic 4
Old 06-12-2006
rbtmoon is on a distinguished road
I did a compression test on my FWC atomic 4 without closing the sea water thru-hull valve. I replace the plugs and tried to start it. The engine would not start after a few tries so I went on the web and discovered that I should have closed the sea water thru-hull valve. Have I damaged the engine? Will it start? How?
Robert Moon rbtmoon@shaw.ca
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
