Blogs
Go Back   SailNet Community > Special Interest Groups > Atomic 4
User Name
Old 10-29-2006
Jim H's Avatar
Jim H Jim H is offline
Jim H is on a distinguished road
Fuel Pump Options
When I bought my boat, the surveyor recommended replacing the mechanical fuel pump with an electric on my Atomic Four.
The mechanical pump is running fine now, but there's no history of it being rebuilt (previous owner admitted he never rebuilt it during the last 14 years). So, I'm thinking it's overdo for rebuild or replacement.
As for the electrics, I'm not excited about having to run another wire and put in the oil pressure sensor for it. Sounds complicated, given that the mechanical is simple and has been running fine for so many years.
So, I'm thinking I'll stick to mechanical, and at least do a rebuild of the current one. However, if I wanted a spare, what would be the best way to go? Moyer has the original entire pump for around $205. They have an improved version for $223. If I installed the new and rebuilt the old as a spare, I'd eat the core charge cost.
An alternate is at http://www.nuclearengine.com/fuel.htm. They have a replacement mechanical for only $42, and it eliminates the sediment cup. Sounds a little too good to be true, but I wonder if others have tried it? I could install it, and keep the rebuilt old as a spare.
Alternatively, I could skip the spare and just rebuild for only $45, but I like the idea of having a back-up if we were crusing for 2-3 weeks at a time.
So, anyone with experience with the nuclearengine pump? Or is there a reason why an electric is the best way to go?
Thanks!
Jim H
Old 07-31-2008
Twoowls Twoowls is offline
Twoowls is on a distinguished road
Just put a good quality electric fuel pump in series with the existing pump. Use the electric if the mechanical fails. The plumbing is simple. Your local auto store has lots of choices, just remember to buy one with no more than 4 psi, otherwise you will overload the carb float and flood the engine. Actually you could have fuel pressure gauge, we use these on race cars to tell what is wrong, but that may be overkill. In any case make sure you have a really good fuel filter, the tanks on most A4s are very old and might have Jimmy Hoffa inside.
Display Modes
vB code is On
HTML code is Off
Water Pump Rebuild/Replacement/Spare Jim H Atomic 4 3 04-19-2007 11:15 PM
Faulty fuel injector pump or? Eleanna Gear & Maintenance 2 10-24-2006 10:19 PM
Lauralee: Here''s your fix. VIEXILE Gear & Maintenance 10 09-08-2003 06:31 AM
Engine Dies HELP!!! lauralee Gear & Maintenance 19 09-01-2003 07:43 AM
Yanmar 2QM15 Bleeding Fuel System - HELP shipley Gear & Maintenance 5 03-11-2002 07:21 PM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
