Blogs
Go Back   SailNet Community > Special Interest Groups > Atomic 4
User Name
Old 08-11-2006
joec43 joec43 is offline
joec43 is on a distinguished road
help, marsolve no longer available??
My exhaust is plugged, years ago I purchased a product called "Marsolve" and circulated it through the system and it cleaned it up well.
It needs it again, and marsolve is no longer available, what do you folks all use??
thanks
Joe
Old 08-21-2006
tenders tenders is offline
tenders is on a distinguished road
A dilute solution of muriatic acid will work too, using it in the same way as you used Marsolve but being a little more careful with the splashes. I think this is discussed at moyermarine.com.
You shouldn't have to do this very often. Is your thermostat running the engine too hot? That causes minerals in seawater to precipitate into the engine block, making the engine run even hotter, making the cycle repeat itself.
Old 08-21-2006
camaraderie's Avatar
camaraderie camaraderie is online now
Moderator
camaraderie has a spectacular aura aboutcamaraderie has a spectacular aura aboutcamaraderie has a spectacular aura about
Ditto tenders advice. Also...do you have zincs on your heat exchanger and are you changing them? Are you sure this is a simple clogging due to salts or could you have thrown an impeller fin into the works?
Old 08-21-2006
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
According to their MSDS online at http://www.marsolve.com/Marsmsdsnew.htm
it is proprietary magic chemicals including "hydrogen chloride aqeuos" and something caustic. In other words, hydrochloric acid aka muriatic acid. You can buy muriatic acid at any masonry supply (and often hidden in the masonry section at Home Depot and such, only the professional brick-and-stone guys know where it is) and it is used for dissolving stubborn calcium buildups and such.
More aggressive than citric aid but readily available.
Old 08-23-2006
GordMay GordMay is offline
GordMay is on a distinguished road
Contact Marsolve:
(203)761-8988 or info@marsolve.com
Display Modes
vB code is On
HTML code is Off
Overheating Atomic 4- Marsolve flush JDAM Gear & Maintenance 6 08-05-2003 09:23 AM
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
